12 No tach signal to ECM 13 Oxygen sensor or circuit 14 Coolant sensor shorted15 Coolant sensor open16 Same as 1521 Throttle valve switch/Wide Open Throttle (WOT) position sensor, 1989 Manifold Absolute Pressure (MAP) circuit failure21 Throttle Position Sensor (TPS) - V6 models22 Starter signal system/1988 and 1989 fuel cut solenoid circuit failure23 Mixture control solenoid circuit failure - 1987 and 1995 Amigo/Pick-up, 1989 to 1994 V6 models23 Power transistor circuit - 1988 to 1994 four-cylinder models23 Intake Air Temperature sensor voltage high - turbo, 1989 to 1995 1.6L, 1.8L, 3.2L vehicles24 Vehicle Speed Sensor (VSS) circuit - V6 models24 Pressure regulator vacuum switching valve - 1988 to 1994 four-cylinder, also Impulse non-turbo25 Intake Air Temperature sensor voltage high - turbo, 1989 to 1995 1.6L, 1.8L, 3.2L vehicles25 AIR VSV circuit failure26 Canister VSV (Vacuum Switching Valve) circuit failure27 Fuel injector driver transistor31 No ignition reference to ECM - 1988 and 1989 models31 Wastegate control - turbo models32 Exhaust Gas Recirculation (EGR) system failure33 Injector circuit failure33 Manifold Absolute Pressure (MAP) sensor voltage high - V6 models34 Manifold Absolute Pressure (MAP) sensor voltage low - V6 models34 Exhaust Gas Recirculation (EGR) sensor or circuit failure35 Power transistor circuit failure41 Crank angle sensor or circuit42 Electronic spark timing circuit failure - V6 models42 Fuel cut-off relay - four-cylinder models43 Throttle valve switch/Wide Open Throttle (WOT) position sensor, 1989 Manifold Absolute Pressure (MAP) circuit failure43 Electronic spark control failure - V6 models43 Idle contact switch always closed (1988 to 1994 four-cylinder, also Impulse non-turbo)43 Knock sensor (1989 to 1995 1.6L, 3.2L)44 Oxygen sensor (lean condition indicated)45 Oxygen sensor (rich condition indicated)51 Fuel cut-off solenoid shorted - carbureted four-cylinder models51 Electronic Control Module (ECM) failure (or prom error)52 Electronic Control Module (ECM) failure (or prom error)53 Faulty Electronic Control Module (ECM) or VCV (Vacuum Switching Valve)54 Shorted vacuum control solenoid, Faulty Electronic Control Module (ECM) - 1988 and 1989 models54 Fuel pump circuit failure - V6 models54 Shorted mixture control solenoid - four-cylinder models55 Faulty Electronic Control Module (ECM) or oxygen sensor61 Air flow sensor circuit failure62 Air flow sensor circuit failure63 Vehicle Speed Sensor (VSS) circuit64 Fuel injector driver transistor65 Throttle valve switch/Wide Open Throttle (WOT) position sensor, 1989 Manifold Absolute Pressure (MAP) circuit failure65 Full throttle switch always on66 Knock sensor failure71 Throttle position switch signal abnormal72 VSV for EGR system short or open73 Same as 72 transister or ground
Коды ошибок по лампе.
Автор
, 12 окт 2009 14:35
В этой теме нет ответов
